Status
Not open for further replies.
1 - 1 of 1 Posts
GSXR Fuel Injection (FI) Code List:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (1000 ONLY)
C28 fix from manual
1 - 1 of 1 Posts
Status
