Ok so ive gotten like 10 speeding tickets now cause my radar detector isnt workin , the dealer told me when i picked up my bike that when i was close to a cop the R in the cluster would start flashing and the closer i got the faster it would flash , well the darn thing hasnt worked since ive had it is there somethin i should be doin first or what ?
see what you have to do is go faster than what you would usually go, that way the radar has a harder time catching up to you
You need to press both buttons simultaneously for 5 minutes. Then alternately press the top and bottom button 10 times in 3 seconds. That turns the detector on. It also arms the 300mm cannon.
Do you have your cloaking device engaged? Radar can't penetrate it, of course, cagers can't see you, either.
just do what I did I like a good chase ever now and then by the cops so I took my factory Radar detector off of the bike that way I can be cought off gaurd when the pigs light up their cerrys after me it's much more fun the just slowing down. try it later
there are some handy hints here, mostly tho its cause I am on a mission to 500 but the end of play tonight.
