It sounds like a fuel delivery issue. Losing power in the proximity of when the secondary injectors start opening up points to insufficient injector flow;they may be clogged.
I've had the exact problem you are describing,on a K5 1K that had very low miles and had sat with fuel in the tank for more than a year. I swapped a fresh,spare set of TB's on and the bike ran 110%. The stumbling/bogging/hesitation/sputtering refusing to rev past 7500-8500rpm issues were gone.
The ECU is the same between the K9-L1. L2 and up,is an entirely different ECU,so I doubt the ECU is your problem.
