Doh..I pulled my '03 gsxr 600 clutch cable and front sprocket off to do some maintenance - put it back together and now I have this extra spring and it won't go into neutral. Yes I am probably an idiot..
...anyone recognize this spring? Clutch return?
Glad I took it apart though - the sprocket nut was finger tight..!!
Inside the sprocket cover?? I don't see a diagram of how that's assembled in the manual though. It's pretty basic. It supplies the return power for your clutch lever.
>Inside the sprocket cover?? I don't see a diagram of how that's assembled in the manual though. It's pretty basic. It supplies the return power for your clutch lever.[/quote]
...I've had the bike 2 months..who knows how long it was running with the sprocket loose - probably took out a bearing. Weird thing is it shifted fine before I torqued down the sprocket.
Most put it in neutral. But when you're engine braking, the same forces apply, so I don't think it would damage anything. I really don't know what else to say. What does it feel like if you shift it out of first trying to go to neutral by hand?
Gsxr 750 2002 I took the spring loaded stva sensor off. How should I put it back on? Do I advance it and turn it back counter clockwise to load up the spring? Is there a way to calibrate it? Or should it go back to the stock marks? When I turn the key to the on position is it supposed to open...
Issues with charging - voltage drops with rpm
My 98 GSXR 750 doesn't charge the battery. When rpm increase, the voltage goes down. The voltage on the battery is a little higher when the engine is running, than it is when the ignition is off.
This is what I've looked at so far:
- I've...
