if you are running a full system all you need is the out side diamiter of your mid pipe and the inside diameter of your canister inlet . If you have the factory pipe you need to find out what the outside diamiter of your mid pipe is and find any after market canister and match the inlet to your mid pipe and you can use any canister you want . thats yhat yosh said when i called with allmost the same question you had.
keith
hope thats what you wanted
keith
