1 - 12 of 12 Posts
I just noticed I'm missing an exhaust bolt. 2015 GSXR 750 with m4 slip on. There is a hanger on the m4 that is connected, but the top of the hanger should mount to the frame and that's where I'm missing the bolt. Attached some pictures. Does anyone know what size that bolt is and where I could get a replacement?
Moderator
www.ronayers.com
Look up your bike, in the "Muffler" pic, part #14
Moderator
Hand-Eye Coordinator
Teach a man to fish..
Also, after finding the size, run over to Sears and pick that bolt up for $.50.
Never pay stealership prices.
I don't find stealership prices on fasteners to be out of line at all.
Discussion Starter #7
I don't see the bolt size in the diagram. It's just listed as "bolt" with a part number. It's #9 on https://www.ronayers.com/oemparts/a/suz/54d9391d87a86524a851b575/muffler. Am I missing it?
I also called the dealership and they don't have it in stock and said they couldn't see the size in their diagram either. I think I'm just going to measure the opening and go to home depot and buy a bunch of bolts and hopefully one of them will fit.
And use Loctite when you reinstall.
:thumbup :thumbup
Discussion Starter #8
If anyone lands here in the future and wants to know, its an 8-1.25 x 16mm bolt.
Also it has a hex flanged head, I think 12 mm hex x 17 mm flange. HD bolts may have other hex/flange sizes but try to get a flanged bolt.
Discussion Starter #10
Is there a benefit to a flanged bolt? I just got a regular bolt and washer... and loctite :grin2:
Moderator
I guess it depends on what you need. When I need a part that day, I'll go to a dealership, if not I can always order online.
The flange provides a more rigid support. But you'll probably be fine with a bolt and washer. Here's what it was:
1 - 12 of 12 Posts
About this Discussion
4 Participants
BillV
Full Forum Listing
