Anybody out there got a decent 4into1 system for an 85 GSXR750F, ideally a Yoshi, Eagle or Vance & Hines. The other thing is which inlet rubbers for 36mm cv carbs will fit my cylinder head as my original ones are starting to split and I will need to replace them soon.
i MAY in the near future have a Yoshi end can/link pipe forsale off mine but dont know if it will fit??? Thinking of putting a road legal back on as the plod are getting to hot round my local roads. If it is up forsale I'll let you know.
p.s Welcome to the board
Dennis Kirk has a V&H system for the `86 (should fit the `85 as well) clicky-click but $356 seems a little pricey for a mild-steel headpipe if ya ask me... on the intake boots... You can prolly use the ones off any gixxer that had 36mm carbs... you'll just have to do a little metal shaping on the head so the transition is smooth (not porting, just matching the holes on the head with the holes in the boots) make it as smooth a transition as you can, and leave the surface a little rough. Don't go into the head any more than you have to with the metal removal.
