61 - 63 of 63 Posts
I have fixed 2 of these clutch switch problems so far on 2008 gsxr600's.
I have found the pin may still slip off of the stock levers. The easy fix is to take a clear hard plastic BIC pen and pull out the little end cap. This cap fits perfectly on the end of the pin.
You will need to cut down the cap so it is pretty small and does not hamper the clutch disengagement. I put a drop of glue to help keep the cap on the end of the pin and have had no more C40 FI errors.
You can also enlarge the screw hole with a bit and take out the taper on the clutch switch then you are able to adjust the position of the clutch switch and that works as well.
2 options for you to fix the clutch switch for no $
B-king Suzuki 1300 error code C40
I have this Error on my motorcycle, Please tell me about it or let me know how i can fix it!!
61 - 63 of 63 Posts
