Hey guys....Im new to the site and totally new to motorcycles. I just bought my 1999 Gixxer 600 a couple weeks ago. Havent done too much riding on it. But sometimes when I go to start it, it starts but dies on me and shuts off after a few seconds. Then the oil light starts flashing. Then other times I'll start it up and ride around on it in first gear and it seems totally fine.
Then today I got on it rode it for a bit it was fine. Turned it off, went to start it again, shut off on me. Now it wont start. Goes to turn over but does nothing. I just checked the oil levels in it, seems like it has too much oil in it. If I drain the oil and put new in up to the required amount....should this fix the problem? Is there anything else I should look into?
Hello All,
I also have a similar problem. I have a 2002 gsx-r 750, and it shuts off if RPM is around 7k or so. it does have too much oil, could it be the cause of shut off? Please let me know!
Someone correct me if I am wrong but if you have tooo much oil in then you can cause air bubbles in your engine (not good) which I would think would make it shut off. Ive always heard its better to put a little less than a little more.
I only have experience with my kaw 250 and that is what I have learned from the professionals from my previous board.
EDIT: Sorry for resurrecting this from the grave, didnt even look at the dates lol
