Switch oils next change and see if that helps. At 51k I would be running a 10w40 or 15w40.
I would lift the tank and see if I could pin point it better when revving. Maybe take the airbox off too but the intake noise may hide the sounds.
It could be your cam chain guides making that noise. If you still have the factory auto cct I would pop it in and see if it makes a difference.
