hi everyone. i would like to know if you could help me.
my owners manual says that every 2 years the engine coolant must be replaced. i dont think this process is very complicated, however if you know of any web which could help me, or if someone that has done it could give me any hint, i would really appreciate it.
i suppose that with taking the appropiate radiator hose, the coolant will be empty, however i dont know which one to take.
so if anyone can help me...
thanks !!!!
regards from spain !!
Pop the radiator cap, and pull the hose off where it connects to the water pump...left side down by the oil pan.....
Make sure the system is bled after filling, or you can get overheating from vapor lock. The bleeder bolt is on top of the block right behind, and under the throttle body.
It's been a while since I've done it so I'm going from memory here.....
He Who Touches Himself
The bleeder bolt is on top of the thermostat housing. But SHOGUN pretty much hit the head of the nail on how to do it.
