Engine bogging?\'s
I took my bike out this weekend since it has been sitting for awhile. When I go to take off the bike stumbles at 6k rpms but once it get past 7k it is ok. The bike was just rejetted, it was also 40 degrees when I was out riding. If anyone could help I would appreceate it, thank you.
Nick
Re: Engine bogging?\'s
what temp was the bike at when u ran it? check the plugs and be sure its jetted correctly
The bike was running from 164 degrees to 176. The plugs have been replaced 1000 miles ago along with the jetting. The bike was fine in the summer time but I was just thinking it might have some thing to do with it being cold outside. Im still not too sure. Any more suggestions, thank you.
I forgot to add I let it warm up to 220 degrees and it still did the same thing.
Can anyone help me?
Change the needle setting see what happens then go up one notch. then if same results put back in same notch and maybe turn your mixture screw in 1/4 then see what happens
