Can someone tell me where these things intersect, or anything to help me find the problem?
I have a short that kills the horn, headlight, and blinkers, but not the gauges.
I know there's a few wiring harnesses, but if someone knows an approximate area to narrow down where/what it is, I would GREATLY appreciate it.
those wiring harneses run under the truple tree and around the fork tube threw to the left side of the bike. ill look it up tonight which color wire/harness runs to those particular accessories.
Found it! There was a bent pin in the big yellow harness.
Originally posted by eSeMeS750WX:
wish i had ur luck (or skill) and turn-around time!!
congrats!!
<font size="2" face="Verdana, Arial">I was amazed. Total luck! I discovered it because when shorted, the blinker light would stay on steady. I just had the problem keep occurring, so I was riding. I noticed it would flash when I hit a bump, so I started tugging on harnesses as I was riding. When I pulled on this one, the short would stop if I held the harness in a tug. So I looked at the wire colors, and concluded that it's in that harness. I then pulled the harness open, and there was some melted plastic where a pin had been bent, and was shorting out. I cleaned it up, straightened it out, and TA-DA!
It's good...
...for now.
