Measure the voltage at the O/W lead to the dealer mode connector when the ignition is on. It should be at battery voltage. If it passes, measure the voltage on the R lead to the nearby SAP connector (8 pins). It should be 5 volts. Do you hear the fuel pump priming?
Based on what you've said, I'm suspicious of additional faults in the wiring harness.
