You will need to change your sprockets over to a 520 also. The stock chain is a 530.
I JUST put a 520 chain & sprockets on my 86 750, I changed the gearing from stock 14-42 to 14-45.
The rear sprocket is so light (alum)I can hardly feel it compared to the stock (steel) one.
If you can wait a few weeks I can give you my input on the gearing change.
Sprocket specialties can hook you up wiyh the correct sprockets
Add a couple teeth to the rear sprocket, your bike is the same as mine. It should have 14 teeth on the countershaft sprocket & 42 on the rear. The # of teeth will be stamped on the rear sprocket. Now on mine I added 3 teeth to the rear which will make the bike quicker, but I will lose a little top speed. My RPM's will be a little higher riding down the freeway but not enough to worry about.
i was wondering about buying this chain ?? right now i have like stock sprockets and was wondering what type i would need to run this chain?? any imput will halp thanks?
what are you opinions on this chain??
thanks
