hello, i'm moving my first steps into ecu flashing, actually using TUNERPRO and a XDF i've bought
I've read around any possible info about ECU-based quickshifter, but for 600/750 k6/k7 i've found very little informations
anyone here can help or address me to a way to accomplish this with TUNERPRO?
i've also read about the basic concepts, using one pin to read the 0v/5v input of the quickshifter sensor, that should start a routine programmed in tunerpro, but despite this general idea i've found no specific informations on this
anyone here was able to accomplish this?
thx!
I've flashed several K6-K7 600/750 ECUs and activated QS (TunerPro.)
Does your XDF have any special options like deceleration fuel cut off?
hello JK750, thx for your answer, I'm on this forum since few days, but the most interesting thread i've read where with your comments ? thx for your contributions
my XDF have this table, related to deceleration fuel cut off. i intended this as a table to reduce engine brake, isnt it?
569724
these are all the other options:
569725
Looks like your definition file has everything but the QS function. Disabling deceleration fuel cut off improves throttle response and cures "herky jerky throttle" https://www.gixxer.com/threads/herky-jerky-throttle-possible-solution.195486/
I'm not lucky ? im trying to find informations about how a routine could be programmed, but i cannot find nothing (im a web dev, but never worked with microcontroller programming, despite some hobbies done on arduino)
about fuel cut, "disabling" it with this file means, if i got it right, jist to put the RPM limit just around 15.000, i mean, in a range so high that it will never be triggered, right?
