1 - 8 of 8 Posts
As the title states, I'm looking to see if their are any Dyno shops in the area. I live near the Cherry Hill area of NJ. Considering this, as I've done a bit of work to my bike and believe its time for a proper Dyno in order to dial everything in and have a custom map made for my PCIII, so the bike runs the best it can!
Thanks!
Markbilt racing in Millville.
They did my bike and I couldnt be happier with the results. They are literally next door to NJMP.
If you don't mind me asking, do you remember the cost?
Not the powers that be, not even close.
250 I think. Had my bike done there too, right down the road from my house.
pretty much everyone i know in the area uses markbilt for their dyno tuning. they do a very good job, and should run you anywhere between $200-$300 depending on how long it takes them to get a good tune and how far off your map is currently.
Discussion Starter #6
Just a quick question...with the 502 and sprocket change, my bike seems to be running at a higher rpm. Will a tune be able to alter that as well?
Um, no. You made your gearing shorter, which will increase rpm at a given mph, that is how it makes the hike accelerate faster. Nothing you can do about that.
1 - 8 of 8 Posts
