KHi all, need some advice please.
Recently fitted some new dyna coils to my 1991 GSXR1100 . When I fitted them originally I think I had the wires crossed on coil 2&3 as when the bike fired up it only ran on 1&4.
There was no wiring diagram with the coils so I've taken an educated guess ��
Ive swapped the wires on coil 2&3 and the bike fires up on all 4 at high revs for a short while and then the ignition fuse blows, if I change the fuse as soon as I turn on the ignition it pops.
Are the coils too much fir the standard igniter unit? Or am I looking for a cable fault.
Is there an easy way to drop the high revs as the idle adjuster is all the way out,
Cheers
Liam
Cheers
Liam
