hi,
what is a proper place to connect power for DVR to make in works only while engine is running?
thx in advance
DVR? Like a dash camera? Fused link directly to the battery, but add a relay that uses power from the key. The only line that's hot only when the engine is running is the fuel pump power. It does go live for the pre-start sequence, so that short cycle might cause your unit problems. Power directly from the key would be best as long as you don't sit there with the key on and the engine off for a long time.
