1 - 8 of 8 Posts
Anyone fabricated a "dummy" petrol tank for their race bike?
I have seen examples of small metal tanks with a dummy fibreglass "cover" the shape of the std tank over that. I have seen a few examples on the web here and there but not much explanation or info to go along with it...
Catalyst composites makes nice fiberglass tank shells, then u just need to TIG up a tank with probably two ports one for the return line, external fuel pump/filter/regulator and done deal. Works great for drag racing, seems like for circuits you would want a fiberglass/carbon fiber or aluminum full tank with foam instead of just the shell. That way u save weight and don't lose fuel capacity, and u can keep the stock pump.
Bearded Viking Admin...
Kinda pointless. You aren't going to save a whole lot of weight except in your wallet and if it's for the SRAD, you're better off putting that money towards a newer, more competitive bike. I had a 600 SRAD race bike with full Öhlins suspension and a 750 engine - I upgraded to a K7 600 and even bone stock I cut my lap times by a couple of seconds over the SRAD immediately.
What does make sense is a fiberglass shell that goes over the stock tank to protect it in a crash along with safety foam in the tank itself.
txs SVS, valuable info.... good idea about the tank cover! can you please explain the safety foam in tank? I'm new to road racing(from mx background)
The safety foam keeps the fuel from sloshing around in the tank.
Discussion Starter #6
txs Anthony, I had that idea, thought the foam was in some way adding to "safety"...
So its more for handling...
Mesonychoteuthis hamitoni
No. Sloshing around is also safety. Also keeps it from gushing out of any tiny little hole from a crash. I've looked at some race series rules (I don't even recall if MX/Enduro/SM/Road race/etc) that required safety foam so all the gas can't dump out in a rupture. The foam slowly releases fuel like water dripping from a sponge, so the engine gets what it needs but it will not dump out even if the cap is ripped off and the tank turned upside down.
1 - 8 of 8 Posts
About this Discussion
5 Participants
geoffro1
Full Forum Listing
