1 - 14 of 14 Posts
I finaly got my bike back together after a crash a few months back, and i don't know If iv'e missed somthing. The fuel pump wont come on unless the stand is up even if the bike is in neutral. is this right?
Thanks Typhon
the pump should come on when u turn the key on if the bike is in neutral i think hmmmmmmm
Yeah dude..it's definitely a lose wire or something. All gixxers, or at least 96 and on you can turn on and start the bike with the kickstand down, it's just that once you put it in first, that the cut-off kicks in. Doesn't sound good if you can't start your bike. Good luck to you man! and by the way, I agree..it's better to ride and wreck then never to ride at all. I'll be at it again in April for sure! Best of luck!
Discussion Starter · #6 ·
Crazy_monkey I hope you can make it all the way to April, it's a long way off. It must help being winter over there. As for us, well, 29C and 24C for the comming weekend guess what i'll be doing
Typhon
Does the "N" light come on?
Discussion Starter · #8 ·
Yeah, the Neutral light comes on when the stand is down, but no fuel pump untill the stand goes up.
Typhon
Humm... Sounds like there might be a relay that is bad or a wire connecting it that isnt working.
GSP 652
Mine want either...maybe it's a 600 thing...my brother's 750 starts with the stand down...hmmmm...that's weird!
Discussion Starter · #11 ·
I'll doubble check every thing when I take my farings off in a week or so to get them painted.
It's not a big deal.
Typhon
my 600 starts with kick stand down, if i am in neutral, and have the clutch pulled in. but when you turn the key you can hear the fuel pump. make sure your connections are correct. sounds like you could have messed up on your connections.
it may sound daft but is the neutral light correct??
have you tried turning the rear wheel to check is really out of gear??
hope you sort it dude
i'll e'mail you a wiring diag for the 600
<font size="2" face="Verdana, Arial">It doesnt really matter if the bike is in gear or not... If the N light is on then the sensor thinks it is in N and the computer and all the relays will also think it is in N... There is only one sensor on the whole bike to do this.
1 - 14 of 14 Posts
