DIY HID Retrofit E46 Bosch Projector D2s Bulb Write Up
This is not an easy task, not for the:wacko or those who don't know how to take things apart. this is a long hard task
i would not recommend you do this if you dont know how to get your hands dirty. If you don't know how to take things apart and put them back together, do not attempt. If you take your bike to the dealer for oil changes, do not attempt. I Mean It.
____________________________________________________________________________________________________
So far that i know and have seen pics of Projectors that work are.
BMW E39 Projector
BMW E46 Projector
BMW Z4 Projector
Acura Tsx Projector
Nissan 350z Projector
Mitsubishi Evo 8 Projector
Infiniti FX 35 Projector:
S2k on Top/Audi A4 Bixenon Bottom
Tools
Heat Gun Professional Grade. not your girlfriends hair dryer
Hot Glue Gun
Black Glue Sticks
Dremel with a sharp bit to cut.
#2 Phillips
small flat head
Allen keys
12mm socket, extension , 1/4" ratchet and 12mm wrench
Good Mechanical/Fabrication Knowledge
Parts
E46 Bosch Projector
D2S Bulb
D2S Ballast
Black Spray Paint
Perma Sealer High Temp
Black Long Funnel
metal straps
the screws that and pinch brackets that come with the straps.
Step 1
Remove upper entire upper cowling from bike. 2 main bolts located at faring stay. 3 bolts on top of each faring. 4 push pins under the cowling. and disconnect the main harness
Step 2
Place complete upper cowling on a table on top of a soft blanket.
disassemble all of it to get to the headlight. remove wire harness
remove fairing stay, air ducts and covers. and upper part of fairing with windscreen attached to it. remove mirrors if you have them
get to the Head Light. this pic shows just the headlight completed all ready.
Step 3
Get the Heat Gun. put it on HIGH for me it was level 8. turn on and let it warm up. there are 3 screws on top of the back of the head light take them out. MAKE SURE you remove the 4 rubbers were the plastic faring mounts to.
now get the heat gun and move it around the edges of the seam. were the plastic glass meets the plastic housing. i kept it about 1" away. moving it all the way around. not holding in one spot. if you do you will melt and ruin your head lamp. keep heating it up it will get hot so hot that it will burn your hands if your not careful. i did this for about 5 mins and was able to pry open the clear cover off the housing.
Step 4
now you need to separate the headlight chrome parts from the assembly
unscrew the 2 adjusting bolts until they are fully released from the plastic part that holds them in place. now look into the assembly. there is a plastic swivel clip that holds the parts together, using a flat screwdriver press the tabs in and release the 2 parts
BMW E39 Projector
BMW E46 Projector
BMW Z4 Projector
Acura Tsx Projector
Tools
Hot Glue Gun
Black Glue Sticks
#2 Phillips
small flat head
Allen keys
Parts
E46 Bosch Projector
D2S Bulb
D2S Ballast
Black Spray Paint
Black Long Funnel
metal straps
Step 1
Step 2
Step 3
Step 4
