Re: Issues with swap (09 750 into 07 600)
dude, just post a damned pic. the throttle bodies are different. will it work? probably, but why fucking bother with that hassle if you don't need to? like joe said, the frames are identical, so the engine should be a direct swap as far as mounting and clearance goes. rickiracer probably used the tank and pump from an 08 because of the fuel hose routing as it goes through opposite sides between the years. i would simply reroute the electrical shit that is interfering and rework a new fuel hose from the pump to injectors that means two easy steps instead of 20 more difficult and possibly problematic ones.
go ahead and try to shoehorn the throttlebodies. you then have to deal with different fuel delivery, different port shapes, and then you have to decide if you can use an 07, or 09 ECU.
