there is a white plug in the trunk with two wires going to it. take a piece of wire,make a U, and stick one end in each side of the plug (like completing a ciruit)
after a couple seconds the display on the guage will turn into a little dash (the dash is your TPS, centered is correct, if its high or low then the TPS needs adjusted) and after the dash there will be a C and numbers. code 00 means all is good. you might get a code, Ex. C18, you have to have a service manual to tell you what the codes mean. I used toi have it, but lost it. hope that helps
thanks john and everyone, the code was, Coo but I need to adjust my trottle position senser. now wheres that?
