1 - 20 of 37 Posts
Mods should definately consider making this a sticky.
These videos are extremely helpful in providing good useful information about your bike's chassis and suspenion. Each one is about an hour long.
Compression damping:
http://www.ustream.tv/recorded/4985094
Fork Springs:
http://www.ustream.tv/recorded/5350380
Shock Springs:
http://www.ustream.tv/recorded/5524985
Fork oils:
http://www.ustream.tv/recorded/5690943
Tires:
http://www.ustream.tv/recorded/6189441
Chassis balance:
http://www.ustream.tv/recorded/4808046
Suspension sag:
http://www.ustream.tv/recorded/4372813
Fork geometry changes (rake/trail):
http://www.ustream.tv/recorded/5863741
Swingarm angle and axle positioning:
http://www.ustream.tv/recorded/6031806
Top out springs (very interesting)
http://www.ustream.tv/recorded/6349484
How to read tire wear - last episode of the season
http://www.ustream.tv/recorded/6516891
Captain Glitterface, the Jacked up thumb Super Meg
Answers a lot of noob technical questions on how stuff works on these machines...
Thanks!
-Brian
This is the kind of thing that gets people to not be so afraid of making small changes on their bikes to see how it reacts good or worse and expecting some sort of result because you actualyl have an idea what it "should" do. I know going to the track i'd set everything up the night before so i wouldnt have to scrwe with anything that day but i think now i'll try some stuff throughout the day and make some notes.
done...
Discussion Starter #8
Sweet, thanks Ant
I'll add additional links as more videos come out. There's a few more they are going to do this season
sounds good kaz...
:thumbup
Discussion Starter #12
was a good one. i'm hoping that a lot will be cleared up with the final episode (tire wear).
I bought both of his videos and one of them he went through a bunch of case studies with various riders at the track and analyzed each ones tires, made some suspension adjustments, sent them out again and they each start coming back in with progressively cleaner looking tires with less tears etc on them.
Discussion Starter #13
Updated with the last video of the season, and a great one too.
In the last episode Dave talks about "doing math" to figure out the rear suspension. Can anyone tell me how's it calculated?
Subscribed............thanks.:thumbup
Birdman
Sub'ed. So do those actually tell you HOW to adjust a bike for your weight or more/less what the advantages are?
I'm at work so when I click on them I get blocked.
I'll check it out at home this week.
Also, I'm sure this is a :squid question but if you weigh say, 225, you adjust the bike for that weight plus whatever the gear weighs right?
Discussion Starter #20
You cannot "adjust" springs that are too stiff or too soft for your weight. At 225 you are a little too heavy for the stock springs in your bike (if in fact you have the stock springs that came with your bike). So you don't adjust, you first replace. Then you adjust the preload and rebound for the proper rate springs for your weight.
1 - 20 of 37 Posts
About this Discussion
29 Participants
kwaka10r
Full Forum Listing
