Hey all. I'm replacing my headbolts and have searched and got prices from $110 to $580 for a set to fit my 98 srad 750. Does anyone know of any place to get a new set for between $50 to under $100? Thanks for your time
Are used bolts really that bad?
Yes especially if your bike has been out of commission for 2 years because after having blown head gasket, and you've replace and had heads resurfaced and block check-out then put all back together and can't figure out how water is getting into oil. then replacing water pump seals then replacing water pump because motor has compression and can't seem to hear or see loss with leak down test. the only thing not done was replacement of head bolts.You then realize that even tho they cost 10 bucks each plus shipping either find a way to pay or let bike sit around for a couple years.
I guess it would just depend on how much you like to ride!
