I have taken the air box out to do a pair valve block off. When I started the bike after puting it all back together the RPM imideatly shoot trough the roof! What have i done wrong??? :dunno
My K6 isn't "blessed" with an ISC so I have limited knowledge of them. There seem to be hoses from the throttle body to it that you might have disconnected (in addition to the electrical connection). As I recall, a symptom with the recalled K7 ISC's was that the RPM would sometimes be very high on startup.
Discussion Starter #7
Thanks! :) my mecanick says the gixxer's can do that if the batteri is low for uncnown reasons :p It seams fine now tho. But maniged to get a problem with the secondary throotle valves now :-O
