1 - 10 of 10 Posts
this will probably be a dumb newb question but still...
I know I want a yoshimura pipe
I know I want a race baffling in it
I know I want carbon fiber
But do I want the bolt on or slip on? and do I want the TRS or Oval (any sound diff?)? which should I get for an 05 750 ? If I get a new pipe (whether bolt or slip) will I have to have anything readjusted? and what is the earliest year pipe I can get that will work on an '05?
Also, what is the best thing to use to touch up a crank case? any particular paint or prep work etc?
as far as the TRS or Oval that is pretty much up to you and your preference.
You will want a Bolt on for your 05. You should be able to get anyhting that is 04-05 BO exhaust.
Most likely you won't need to adjust anything, but if idle is a little rough you can bump it up a little bit. That is explained in the owners manual.
Hey man i've got an '04 600 with the carbon trs and i love it.
you can only get a bolt on without cutting. Slip on is not available for the '04-'05 600.
Don't have to adjust anything with just the bolt on. Full system is another story. Good luck man
and post some pics when you get a chance
1 - 10 of 10 Posts
