· Premium Member
I'm swapping the '87 1100 motor into the '89 750 frame and would like to use the cooler from the 750. It isn't damaged (the 1100 cooler is) and it fits the frame. I don't know if the 1100 will. Can I drop the oil pan and swap them out? The fittings on the engine are different, so do I have to have lines made? Help. Thanks. Troy 341
the sling shot(88/89) 750 had the same oil pan as the 86-88 1100 if i'm not mistaken...but if not, just keep the oil cooler with the oil pan and pickup that you wish to use and everything will interchange...keep your 750 cooler and put your 750 oil pan and oil pickup on the 1100 motor and you will be ok...
dwayne
