I am constructing my first computer from scratch
Everything is going good, however the computer/bios is registering the processor as 2.5 or 2.4 ghz instead of what it's suppose to be (3.0ghz).
I did a little search on the internet. Most of them suggested to adjust the motherboard's front bus. Now, i don't have a faulkin clue where to start. A bus to me is a big yellow vehicle with stop a arm
How do i get the computer to read the processor as the real speed of 3.0 ghz?
TIA
When you first turn the PC on you will see the BIOS posting(black screen with lots of text), while it is doing this you should be able to tap either the delete key or F1 key. Hit it a few times and it should take you into the BIOS. Once in there, all you should have to do is go to the menu for CPU speed and choose the 3.0Ghz or 3000Mhz option.
What motherboard do you have?
I'll give this a try later today.
http://de.shuttle.com/en/desktopdefault.aspx/tabid-36/7_read-8897/
AMIBIOS
Socket 478, 800/533/400FSB
VIA PT800/8235 Chipset
Slots: AGP 8X, 4x PCI
ATA133 und Serial-ATA Raid,
USB2.0, DDR400, LAN,
AC'97, ATX Form Factor
Chipset:
VIA PT800 Northbridge / VIA VT8237 Southbridge
System clock: 400/533/800MHz
CPU support
Sockel 478 supports
Intel Pentium 4 and Celeron processors
with 400,533 or 800MHz FSB and Hyper-Threading support
Expansion slots:
1 x AGP (v3.0) slot supports 8X Modus
Important note: AGP-slot supports only 1,5V-mode
4 x 32 Bit PCI (v2.2)
Onboard IDE controller
2-channel enhanced PCI IDE for up to 4 IDE devices
supports UltraDMA/133 (ATA133)
Serial-ATA controller
2-channel Serial-ATA 150 for up to 2 hard discs
supports RAID-mode
Multimedia:
AC97 2.1 stereo sound
Connectors on the backpanel: line-In, line-out, microphone, MIDI/gameport
Further line-ins on the mainboard audio-in for CD-ROM and AUX.
Networking:
10/100MBit LAN
VIA VT6103
Backpanel-connectors:
1 x PS/2-Mouse
1 x PS/2-Keyboard
1 x Parallel (SSP/EPP/ECP)
1 x Serial
1 x LAN (RJ45)
4 x USB 2.0 (4 more onboard)
Audio: line-in, line-out, microphone
Onboard-connectors:
2 x Serial-ATA150 RAID
1 x Floppy drive (up to 2,88 MB)
4 x USB 2.0 (4 more on the backpanel)
1 x WOL (Wake on Lan)
2 x Audio frontpanel-connectors (microphone and line-out)
2 x CD-ROM audio-in
2 x Fan (CPU, AGP)
Memory:
2 x 184-pin slots
for PC1600 (DDR200), PC2100 (DDR266), PC2700 (DDR333) or PC3200 (DDR400) unbuffered DDR SDRAM memory
with 100, 133, 166 resp. 200MHz clock frequency up to a total capacity of 2GB
When using DDR400, then only one memory module is supported.
Hardware-monitoring
CPU-temperature, system voltage and fan revolution
Power Management
ACPI Version 1.0 (Advanced Configuration and Power Interface)
On/Off-button with two functions: suspend-mode / soft-off
BIOS
AMI BIOS Version
stored in 4MBit LPC Flash-memory chip
ATX-power supply connector
Standard 20-Pin-ATX-power supply connector and additional 4-Pin 12V-connector
Form Factor
ATX: 30.5 x 19 cm
The problem is that the bus is too long and therefore can't operate at the full 3.0ghz. It just scales back to 2.4 or 2.5ghz. You'll need to contact the motherboard manufacturer and request a "short bus"...they'll know exactly what you're talking about.
Beany-
You messin' with me??
Although I did ride the "short bus" and/or "retard racer", you think the motherboard MANUFACTURE will replace my motherboard with a yellow short bus motherboard? Will they need a doctor documentation that I qualify for a yellow short bus board??
Beany-
Hah, I'm sure that after they talk to you over the phone that no dr documentation will be needed.
