1 - 10 of 10 Posts
:scratch
This guy has a CTS-V: front-engined V8 with a blower.
He stuck a turbo on waaay back in the rear to compress the intake air back up to the front and into the blower?
This is a thing?
Yup,tis a thing. Just saw that vid posted on TalonTSI97's page saturday mornin and thought of you and your sexxy beast
You obviously know more about this than I because after your post, I googled TalonTSI97 and am no further ahead than before :lol
What do you think about repairing the turbo? Many write that it is better to buy a new one. I myself have now problems with the turbocharger, and I think the best way to proceed in this situation. Already even found the website to buy and replace, but still want to save money and just make repairs
NYYYYYAHHHHHHHHHHHHH!
i hate rearmounts too friggin laggy coming onto boost and the response is shithouse.
good for drag cars maybe but shit for anything else.
had a mate with rear mounts to get better weight distribution, we ended up canning it because you had to be on the go pedal about mid-corner/pre apex to have the turbos spooled for corner exit, switched back to standard mount with water to air cooler, boom, insta spool was back.
exhaust gasses slow too much by the time they're at the rear of the car.
as for repairing a turbo, if the housing isn't damaged i always just throw a new balanced cartridge in and put it together, not a hard process.
Discussion Starter #6
I've since read that Mercedes 'Bluetec' diesel uses a little turbo feeding a big turbo for snappy response / big power. I guess it is a thing.
Although I agree with @XCSEDAN about rearmount. I recall back in the 80s, reading how you want to keep the turbos as close as you can to the action or else the entire volume of the exhaust acts like a compressor tank, taking more time to spool-up the turbo. Then throw in a car length's of the same shit on the cold air side to soften-up that too. I guess once it's all up to speed, it must make a difference.
Rear mounts are for people that cannot build a proper turbo setup. They are inferior, always.
damn straight they are... unless its for a drag car... then i can understand....
tell you what though, i love compound boost, mate has a compound boost cummins in his patrol.... god damn does it make power!!
In most cases, a turbocharger can be repaired, unless the outer housings are damaged. It is imperative that you get a warranty in case the turbo fails again. ... The worn parts will be replaced by the turbo specialist and your turbocharger will be as good as new.
1 - 10 of 10 Posts
