1 - 13 of 13 Posts
After asking the same question of the people at Dyna...The answer is YES.
The 2.2 ohm (part #DC4-1) is what you're looking to have. Give them a call at 626.963.1669 if you have other concerns.
Man, You guy's just scared the crap out of me! (even more than those clowns) I've got the 3 OHM Dyna's on my 86 1100 and I could have sworn the guy told me not to use the 2.2's. Well, I just gave them a call, and yes the 2.2's are recomended (Stock ignition or dyna 2000) But, if your running a Power Pak (like me), its the 3.0'S! Whew! (I really didnt want to buy a new set of coils)
Anyway, great information guys, and very accurate.
Thanks, and keep up the good work!
Dave.
Jeff,
You are the man!
I love it when electronics smoke! (As long as their not mine that is!)
if you're using the stock ecu, you're technically supposed to use the 3 ohm coils.....using ones that have a lower primary winding resistance can theoretically cause problems. realistically, people have gotten away with using 2.2's with no issues....
in case anybody's wondering, using 1 ohm ignition coils with the stock ecu will cause you to go through ignition fuses at the rate of about one every two minutes or so.
(don't ask.
does anyone have instructions for the dyna 2000 , and which coils are the green ones?
what's the going price on those? I think that could be the reason I keep fouling plugs on my 86-1100. I think the ones that are on there are Excells or something like that. They are canary yellow. has anyone had experience with those ?
Hi everybody I'm happy to find you guys and I hope you can help. I have an 86 750 and just reciently I have started noticing power lags and in the last few days the tach would die and I would experance extreme powerloss but the bike would still run. I think one of my coils is going but after testing with a meter it looks fine. if it is a coil problem which Dyna should I replace it with.
My gixxer is mostly orignal mechanicly.
Thanks for any help Phil
<font size="2" face="Verdana, Arial">i haven't heard anything really bad about the excels....if you're fouling all of your plugs constantly, the problem isn't likely to be the coils.
if i remember correctly, i paid around $50-60 each for dynas, but that was several years ago.
<font size="2" face="Verdana, Arial">next time you lose power on your bike, try spraying the headers with a spray bottle filled with water to see which cylinders are misfiring....it could clue you in on which coil is going bad (if it's even a coil problem at all).
1 - 13 of 13 Posts
