Anybody know what the wiring should be for the Coils on a 96' gsxr 750? I mean on the back of the coils there are 2 electrical wires that connect to it. On the top coil, one closest to tank, there is a white wire and an orange/white wire. On the botton coil, there is a Black/yellow and Orange/white wire. Can someone look on their bike and tell me what order from tank to ground is the order? Or does it matter. Mine right now is White on top, orange/white under. then Orange/white, black/yellow.
Thanks guys.
rzr
I don't think the connections matter as long as you have an O/W lead on each coil, the white lead on the 1/4 coil, and the B/Y lead on the 2/3 coil.
If you're chaising a spark problem, those leads between the coils and the CDI sometimes go bad. It starts off intermittent and then 2 cylinders go out completely. Mine failed just behind the connectors at the coil. You couldn't see it on the outside, but if you felt it you could tell the wire had gone away.
You can trouble shoot it by swapping the coil leads. If the dead or weak coil comes alive, it's the wires.
You probably know not to turn the bike over without grounded spark plugs on the coils.
Thanks for your input. I checked the wiring schematic and it shows the said colored wires for each coil. But it didn't show which went where. I'm not sure if it was the replacement of the new APE Manual CCT or me switching the wires on the back of the 2/3 coil, but now seems to really rev up and be more responsive. I thought maybe the wires had something to do with firing order? Haven't taken it out for a ride yet as the weather is now becoming shite (must mean bike is in good running order, can't ride it now cause of weather is a dead give away). As for adjustment, I followed the post at the beginning of the forum and when I started it, it was clacking like crazy. Turned engine off and tighten CCT a little, fired her up and sound was gone and bike ran well. Question again, I can rev it up to say 7000 and sounds crisp, when I let off and RPMS drop, can hear a little "clacking" noise for about 1 second then stops. Only makes sound when I let off throttle and idle drops. Any Ideas anyone??
Thanks for all your help.
rzr
