1 - 16 of 16 Posts
c\'mon 7-11 guys
Any 7-11 guys use the 750 lines on their 1100?
I have an '88 750 frame with an '89 Katana motor in it, but I need oil lines for it. I know where there is an oil cooler and lines for an '88 1100. Will this work?
btw - the Katana motor came with the banjo-bolt style oil fittings, while the ones on my GSXR were the ones with the large hex-head, if that makes a difference.
[ 01-06-2002: Message edited by: dinoracer ]</p>
Re: c\'mon 7-11 guys
the '88 1100 oil cooler uses large banjos on both ends....however, on the 1100, the banjos bolt to the bottom of the pan, whereas on the katana it bolts to the front. so i don't think the lines will fit correctly....
another alternative if you have the katana oil lines would be to get the '88-92 750 oil cooler....they use the same attachment at the cooler as the katana. the '88-89 coolers are flat and should bolt right up to your '88 frame, the 90-92's are larger and curved, so you might have to fiddle around with the mounts (not sure on this, though, it may just bolt right up).
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by jeff:
the 90-92's are larger and curved, so you might have to fiddle around with the mounts (not sure on this, though, it may just bolt right up).<hr></blockquote>
NOOOO stay away from the 91-92 oil cooler's BIG $$$$$$$$ don't even bother to look for one. they are a bit larger and curved like jeff said, but you'd be better off sticking with the 88-90 one's.
YAAFM Mod
I hade had three 7-11's over the years and still have a 88 7-11 that I converted back in 89. You can use the pan from the 88-89 750 and use the lines from a 89-90 1100. I have converted mine to the 91 curved cooler (15% better cooling) and also have a second cooler mounted under the tail (old Yosh kit)
Doug
G
awe man I came into this post because I thought 7-11 was having a special sale on turbins!! I got a 93 6/9 does that count? ha ha ha.......
[ 01-17-2002: Message edited by: GixxerRacer371 ]</p>
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by GixxerRacer371:
[QBI got a 93 6/9 does that count? ha ha ha.......
[ 01-17-2002: Message edited by: GixxerRacer371 ][/QB]<hr></blockquote>
<hr></blockquote>
Ummmm...no.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Pod99966:
<hr></blockquote>
click here:
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=601190156&ed=1012454646
Folloe the link to the other viewed items and there is a cheap 91 curved oil cooler it is my buddies up for sale and cheap too / MY ebay GSXRFISH/jimmy hat
1 - 16 of 16 Posts
