1 - 1 of 1 Posts
Have an issue with the clutch push rod not retracting after I forcible pushed in the
568720
clutch release arm... any suggestions?
The clutch push rod just freely maneuvers without any tension
568721
. And if I push the clutch screw in from opposite side then the rod just slides back outward.. side to side free play.
568722
Don't want to tear it down and do the whole gasket thing. Did the spring or whatever in between the pushrod and adjust screw fall out or just stuck?
1 - 1 of 1 Posts
