I Have a K7 gsxr 600 and my chain broke causing my clutch push rod to bend and make the seal lean. I got a new seal and push rod but unsure of the proper way to remove the old seal and install the new one.
How do I remove the old seal? Just pull it out with a puller?
Then how do I set the new seal in place? I know there is a little plate with two Allen heads that go over the seal but is that all that holds it in place or should I put a sealant in there? Any help would be greatly appreciated.
Thank You
Do a search;there are a few hacks that circumvent having to split the cases but the proper way to ensure a 100% seal is,to split the cases and do it the right way.
Not sure,I just posted what I recalled off the top of my head about 600's that had that issue and how most of the repairs were hack jobs
