Ok so I recently changed my clutch on my 07 gsxr 600. when putting clutch springs back on a screw broke causing 1 of the clutch springs to not be secured. idk if I need to order a new clutch case or if I even really need the 1 spring. i dnt wanna make things worse. please help
Accurate Butt Dyno
Ok, so you broke a clutch spring bolt? That's what I'm understanding?
If so, remove all the other bolts and springs, pull the face plate off and you should be able to grab onto the broken bolt and back it out there shouldn't be any tension on it so should come out no problem.
Then go to your dealer and order a new bolt. Part #21482-41G00 its like a $2 part.
