Back the thumbwheel adjuster all the way out so you've got some slack in the cable.
Then undo the bolt that goes through the lever. With the lever out of the perch rotate the ball from it's locator and your away!
I tried undoing the bolt that goes through the lever.......but it is not turning!!! it seems like it's just staying in the same place. I am guessing the tread is stripped?
