1 - 11 of 11 Posts
So, I replaced the clutch cover gasket on my 07 GSXR 600. It was leaking out of the top left, I've noticed from the previous owner there was some type of white bond on the old gasket (assuming it's been leaking before). The old gasket was broken in a few places and needed replacing. After replacing the gasket after one day it's back to leaking again. Is there some type of "bond" out there I can use to stop the leak? I don't see any cracks in the case, but this bike has definitely been down a few times.
Appreciate the help y'all.
I assume that yours gets the same as my K6 1000. Suzuki recommends Suzuki Bond 1207B, which I think is the same as Three Bond 1207B. Also see the recommendations in the K5/K6 1000 clutch mod sticky. Note that some of the attaching bolts use gasket washers and they're supposed to be replaced each time the cover is off. See the service manual, ENGINE>ENGINE COMPONENTS REMOVABLE WITH ENGINE IN PLACE>CLUTCH COVER>INSTALLATION. Clean the surfaces well. Racers sometimes omit the sealant on one side so that it doesn't break up when the cover is removed. But they will suffer small leaks.
P.S. Don't know about the clutch cover but there are some aftermarket stator cover gaskets that have a bead of sealant incorporated into the gasket. It seems like a good idea but I have limited experience with them.
I assume that yours gets the same as my K6 1000. Suzuki recommends Suzuki Bond 1207B, which I think is the same as Three Bond 1207B. Also see the recommendations in the K5/K6 1000 clutch mod sticky. Note that some of the attaching bolts use gasket washers and there are supposed to be replaced each time the cover is off. See the service manual, ENGINE>ENGINE COMPONENTS REMOVABLE WITH ENGINE IN PLACE>CLUTCH COVER>INSTALLATION. Clean the surfaces well. Racers sometimes omit the sealant on one side so that it doesn't break up when the cover is removed. But they will suffer small leaks.
Never knew those bolts needed washers! Can't seem to find them online though. I may just have to give that Three Bond a shot, appreciate your help man!
There's also 2 spots on the surface of the cases that your supposed to put a dot of silicone sealant. Its at the 2 joints where the cases split.
Boom! There it is. It's leaking at the top right section where the arrow is lol. Y'all are awesome.
Discussion Starter #8
"Can't seem to find them online though."
It's #6 .
Thanks man. I tried the three bond, still leaking out of the case at that damn bolt that requires the gasket lol. Gonna have to order one. Do you think I should use the gasket and some three bond or just attempt it with the gasket?
Hand-Eye Coordinator
Did you replace the gasket, again? If you just took the cover off and then used the same gasket with the sealant, you may still get a leak. You also need to thoroughly clean those points before adding the sealant.
Discussion Starter #10
I did not use a new gasket (I just put a new one on a week ago and it looks ok). Do these gaskets get ruined after compression and decompression? I am aware I need to clean the entire area.
Well, I bet that after a close inspection, you may notice a little damage at those case points.
1 - 11 of 11 Posts
