Can someone please tell me where i can get a kit for lubing up my clutch cable, or can someone let me know what home shop method they use. Any info would be greatly appreciated. Thanks in advance for any help!!
I use a little device that clamps around the end of the cable,you plug a can of lube (wd40 or chain lube ect) into it and it blows the lube through the cable.(I use crc dry glide)any good bike shop should be able to get one for you.
Just make a little paper funnel by wrapping a peice of paper around the end of the cable, attach it with tape. Pour a little motor oil down the cable while you slide it up and down. Once you see oil drip out the bottom end, you know its lubed.
