I need some help with clutch adjustment, its still engaging when I pull in the lever and the lever seems to be adjusted fine, wondering if anyone can walk me through the process adjusting it elsewhere. I dont have a manual for it, but will definitely be getting one in the near future, in the meantime, I'll hope someone with a manual or knowledge can help me out. Thanks
1.You have to pull the rubber dust cover off the countershaft sprocket cover
2.Unjam the lock nut
3.Loosen the little stud with a flat screw driver all till there is no pressure on the clutch actuator rod.
4.Tighten it till the actuator touches the rod.
5.Then set the clutch lever with the two adjustments.
6. If it feels right then tighten the jam nut.
7. Put the dust cover back on and go for a ride
