1 - 14 of 14 Posts
I'm interested to learn what is most owners city street cruising rpm? I try to keep mine under 5k. I don't think the GS becomes the GSXR until 8k+ after which in gears 2+ hyperspace is entered. Below which in normal traffic the GSXR is just a sexy looking race bike.
When I had mine, I was usually around the 6k
But I would guess the 'most comfortable' rpm range also has to do with how your bike is set up
Bone stock, with the SET still engaged and the woodstove still mounted, you'll have more low end grunt than with a full system and tuned for top end power
100% factory original with no plans to change anything. I'll take the grunt over 180mph anyday. I agree 6k is the top end of most city street cruising, although an occasional 8k quick twist is fun.
I never let mine drop below 5k unless I was going to stop.
Geek, thanks for the response bro I toteilly understand what your saying. I'm kinda the opposite I try not to push mine over 6k in normal street traffic, unless I was going to jet. Highway is another thing altogether. I think 77mph in 6th is around 7k for me but I don't know for sure.
RPM is always a delicate subject. Everyone is use to their car. Idling below 1000RPM, redliing at 6k, maybe 7k, and crusing at 2500 on the interstate. Plus you're inside with sound dampers all around you. So this feeling is what people expect from their bike. They turn the idle down so far it can't breathe, and lug the engine trying to keep if from soundling like they're hauling as. The fact is these engines are designed to turn really really fast. Keep it in the upper 2/3 of the RPM band. Don't worry what it sounds like.
Speed and gear selection is probably more important than RPM in the city.
Outside the city, a good rule of thumb is the other way around for me ;)
Discussion Starter #8
Wow Geek again you've helped me a heckuva lot. You've nailed exactly what my concern is. It just naturally bothers me to keep the motor above 10k for any longer than a couple of secs. Correct me if I'm wrong but 3rd gear+ @ 10k is definitely going to be 100mph+? Hell 1st gear @10k will really be 55mph+!
Stay in the upper 2/3. For 0-15k, 0-5k is the no-go zone. 5k-15k is good.
I have a Suzuki TL1000S and a Aprilia RSV Mille and just bought a GSX-R 750 a week ago, and I havenť been riding a inline 4 cylinder bike since a little more than 4 years ago when a sold my Honda 949 Fireblade, so I have to "readjust" myself to higher revs again.
On the 750 I'm around 5,5-7k rpm on city streets (on the TL1000 or the Mille I can be in 6th gear on 2500-3000 rpm when just rolling down the streets).
Discussion Starter #12
Thats still fast enough to get a 'safe driving award' or get the honor to wear a shiny pair of silver bracelets anywhere you ride which is pretty freakin' impressive for third damn gear!
Discussion Starter #13
Jeez bro 7k in 6th is around 90!
I tend to keep the RPM higher and rev out a bit more, because I found that by lugging it around I ended up having some mild plug fouling.
1 - 14 of 14 Posts
