how does the charging system on a 96 gsxr 750 work? i bought a new battery and i am still having trouble starting after i go for a ride, like the new battery worked for a day and now i go to turn it over and it cranks twice and then just quits??????????????
sounds like the generator is shot. mine has the same problem there is a gen. on ebay for 49 bucks buy it now but I don't have enough cash to buy it now. but i'm runnin off the battery with a switch for the headlights and can ride for hours. when I see a cop I turn the head light on. but only for a minute
yea, well i it is going in tomorow, how did you wire your head light switch?
I would check your Regulator/Rectifier. Generators rarely go bad. I'd have someone look at the entire charging system before you buy anything.
go to a parts store pick up a simplt two wire on off switch find a main ppower wire that runs the headlamp.splice the wire and the switch in. I went for the high beams so I could ride with it on high but the switch was off. if needed flip it down to low and low comes on
