Thick tacky stuff usually sprays out of a can.I think that you'll be OK. Suzuki likes to say:
Lubricate the drive chain with a heavy weight motor oil. Wipe off any excess oil or chain lubricant. Do not use any oil sold commercially as “drive chain oil”. Such oil can damage the O-rings.
I've never understood what "drive chain oil" is but gather it's something else.
Don't use oil. It makes a mess and gets on the rim and tire. I have used a product recommended on this site. It was Dupont chain lube with teflon. It worked OK but was still a bit messy. My chain lube routine is to ride enough to warm the chain up. Throw a stand under the rear. Start up the bike and put in in 2nd gear. I then spray Maxima chain wax on both left and right inside sides of the chain as it passes by. I use the spray tube that comes with the chain wax. That way you stay at a safe distance because you don't want your body parts getting mixed up in a moving chain. After lubing I park the bike and let the wax set up overnight. The Maxima chain wax is very clean and almost none of it flings off onto the rim and tire. I lube my chain at 300 - 500 mile intervals. Once a year I will spray the chain down with WD-40 until the chain is wet and dripping. Then I take an old rag and wipe off the WD-40 and grime. If your chain is very dirty you may need to do this twice. I then let the chain dry out before lubing with chain wax.Guys just looking for recommendation, the manual says you can lubricate the drive chain with high viscosity oil, l have a bottle with 140 grade gear oil l used in my old truck, ls that going to hurt the x-rings or is it good to go?
