The fuel filter glue may have gummed up some passages in the carb. I know you cleaned the carbs, but in this case, have you verified that all the air passages are pristine? Air jet inlet, emulsion tube (needle jet), and if there is any accelerator pump circuit for this carb that may be clogged.
Check vacuum hose, TPS sensor connection.
