Do u remove the tank or leave it on ?
If u displace it, where is a good place to rest it without damaging the fuel pump assembly ?
Ive lifted the tank up to set up the adaptors and hoses, and i cant see the screws because the tank is in the way.
Ive seen them [synch screws] with the tank and air filter housing off. But they're out of sight when im viewing from the side of the bike
KaTz
[ 09-20-2002, 03:48 AM: Message edited by: KaTz ]
Best thing to do is get a small tank to use when doing the synch.Since you don't rev more than +-3000rpm while setting up the carbs you don't need a fuel pump so a lawnmower tank will do the job quite well.
Sexy Irish Man God
Look into getting a Aux. Fuel tank. It pretty much is a waterbottle that you hook up to the bike. Cost around 40.00 USD out here. They are very handy
jontflesh
Thanx for the replies
I was tempted to use a remote petrol tank, but there wasnt one around which i could adapt the hose to.
After a bit of head scratching, i managed to prop the tank up with a block of wood on the airbox, and a block of wood on the rear shock's top mounting nut.
THe tank was stable and everything's connected
[apart fro mthe vacumn hose for obvious reasons]
Then i proceeded to burn my knuckles and fingers while tweaking the synchizing screws
It wasnt far off since the last synch 6000km's ago.... from memory, it was within +\- 1cmHg. Now it's within +\- 0.25 mm Hg
KaTz
