Good morning i have a question about my carbs
i have an 87 gsxr1100 with 88 mikuni carbs on it with 160 main jets and a yosh pipe
now my problem
i am having a problem with the #1 cyl burning rich ( plug is black )
the rest are burning pretty clean some # 4 is kind of white but 2 and 3 are good
the carbs are in sink and clean
were would i look or what should i do
thanks
chris
Assuming all of the needles are set the same, et cetera I'd suggest checking float height and having a look at the needle 'n seat assembly on the "wet" cylinder.
Ed
checked all the needles and float hight and it is all in speck
the plug isnt wet it is sooty black it gathers so much soot it quits sparking i clean the plug off and it will run for a little at normal speeds and then it is back to not sparking again
any other ideas
thanks
I pull all of the plugs and compare the spark on all of them. The coil might be getting weak and not give you a good spark on that cylinder. When you have all the plugs out, I would do a compression check too.
