1 - 9 of 9 Posts
When putting the clip on the fourth notch am i reading needle from top to bottom or bottom to top top being where the circlip goes thanks for the response
i guess the needles for a 600 are not adjustable in the same way, as there is only one slot for the E-clip. if so, do you shim the needles up for a richer mixture.
Discussion Starter · #7 ·
well when you purchase a jet kit it comes with more needles that have slots on it like those oem does not on 750 or 600 and yes tey would usually use shims to get the same effect as raising it
Discussion Starter · #9 ·
This is the size of washer to use i put a circlip next to it to show the difference
1 - 9 of 9 Posts
