1 - 8 of 8 Posts
I was at Tap Plastics today picking up some delrin and I noticed they have a new product called Tireplast, which is an 1/8" thick mat made out of recycled tire and other plastic. Since it's made out of recycled tires I'd guess it's fairly chemical resistant, and I believe the melting point of rubber is somewhere between 230 to 350 degrees F (the workers there didn't have a clue).
At $19.95 for a 4'x4' sheet it's probably cheap enough to pick one up and see if it would make a good carb heat shield.
Anyway, if you do decide to try it and it melts/catches on fire which in turn causes your tank to blow up which in turn causes your bike to burn down it's your own fault...
Yancy
YAAFM Mod
Doh! You make it sound to good to pass up! I think I'll try it first thing tomarrow!
Bones
use a thin sheet of aluminum..bend to fit..trim..cut holes for carbs..apply heat shield on underside of aluminum. I have done it to all of my oil cooled bikes and it works ALOT better. You will notice a big drop temp wise on your tank when your riding. I also like to use a small fan on the oil cooler and ducting to direct cool air onto cooler/cases.
<font size="2" face="Verdana, Arial">Can you post a pic of your heat sheild??? I'm having problems when the bike gets hot. It runs fine when I first start out but after some thrashing it craps out. It will barely run, and not be able to increase the rpm. So did these bikes have a heat sheild when they were new???? Or has everyone but me noticed that they need one???
1 - 8 of 8 Posts
