1 - 10 of 10 Posts
Is there a trick to getting those stupid screws out holding the carb boots to the head. Thought I'd take some suggestions before i start making a mess.
Discussion Starter #2
There's a suggestion of hitting the screws with a hammer to shock them to get them out. I was concerned about doing this.
I'm sad to say i broke off part of the 1100 head. live and learn
I just did the boots on a '94 750 and a '95 1100. Both seemed to have a lot of thread locker. I used heat on a screwdriver before twisting but kept the heat on the conservative side to avoid damaging the boots. I was able to get 15 of the 16 out. I've got a little project on the 750 now even though I got a 93% on my efforts:unsure:
It was the last screw that the head broke. I'll need to get it wielded. I was impatient. Should have used all the regular stuff first. WD40 and such
I noticed how the lower row are kind of hanging out in space and took it easy with the hammer. I did smack the screw driver bits into the screws multiple times durring the process and used a center punch ar a 45 degree angle to try to shock them too. I think heat is the key but don't know how to get enough in there without damaging the boots.
Accurate Butt Dyno
I work on allot of pre 1987 bikes, and by far the tool that saves me the most grief and money is my impact driver with a good JAS bit, one swift wack with a hammer does the trick 99% of the time.
Second the impact screwdriver. Once you have them out, replace them with socket head bolts so you won't have to deal with it again. Much easier the next time.
another yes on impact driver. just don't smack it too hard, because i also once broke part of the intake, but that was only once out of like 3 cylinder heads, so it's a good avereage.
1 - 10 of 10 Posts
